Подскажите пожалуйста, как перевести приборную панель с миль в км.
Плата от A6 C4 2,8 Англичанки
Приборная панель A6 C4
http://www.ross-tech.com/vag-com/cars/audiB5.html
17-Instruments: -- KWP-1281
VAG-COM Works fine.
Immobilizer Procedures in the Ross-Tech Wiki
Note: US/Canada model Audi A4/S4 do not have Immobilizers.
Recode for warning lamps (through 1999 only):
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock
Look at the fourth digit in the coding (Cylinders):
4 - 4-cylinder
6 - 6-cylinder
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
A complete instrument cluster coding chart which includes 2000 and newer cars is available in the Ross-Tech Wiki.
Change Language Displayed:
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter channel 04
The available languages are :
00001 - German
00002 - English
00003 - French
00004 - Italian
00005 - Spanish
00006 - Portuguese
[Save]
Правда - видывали мы панели, с которыми эти номера не прокатывали...
VAG-COM Works fine.
[Select]
[17 - Instruments]
[Recode - 07]
[Do It!]
4 - 4-cylinder
6 - 6-cylinder
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter channel 04
00001 - German
00002 - English
00003 - French
00004 - Italian
00005 - Spanish
00006 - Portuguese
[Save]
